hi i seem to have a major problem with my tcv setup the left deck has 100% but the right deck has 0% and will not find the tcv when its playing but if i load up a track on the right deck it will play the track but the needel drop will not work. in the tcv setup on the right deck the green line is ok but the red line has many spikes and goes all over the place but the left deck is ok. i have reinstaled my os and vdj and maya 44 usb drivers and still the same problem please any one help me.
ps i have followed all the setup plans and was wondering if its the sound card.
Posted Sat 01 Oct 05 @ 1:26 am
What sound card are you using?
Posted Sat 01 Oct 05 @ 3:46 am
hi im using a maya 44 usb on my hp laptop
Posted Sat 01 Oct 05 @ 11:53 am
Are you using the bundled ASIO drivers or the latest 2.55 from Audiotrak webpage?
http://www.audiotrak.de/down/maya44usb_v255.zip if not. Try those and let us know.
Posted Sat 01 Oct 05 @ 3:45 pm
hi all i have tested the maya 44 on my g5 and it is the sound card that is faulty input 3 is just giving static so its back to the shop to get a replacement
Posted Sat 01 Oct 05 @ 6:10 pm
Ok, When your new card arrives, you don't have any troubles at all.
Be well!
Be well!
Posted Sat 01 Oct 05 @ 6:11 pm
