Mixer or Hercules DJ Console for start mix?
I have bought already Virtual DJ :)
Thanks
Thanks
Posted Wed 31 Mar 04 @ 10:39 am
mixer
Posted Wed 31 Mar 04 @ 11:09 am
the mixer,
Posted Wed 31 Mar 04 @ 6:02 pm
Thanks you so much tomorrow I will go to buy a mixer 2 or 3 channel? thanks..
Posted Wed 31 Mar 04 @ 7:29 pm
3 channel would make sense if you can afford it. If you are DJing and your PC crashes you could have, say, an iPOD plugged into the third channel and quickly switch to that whilst you fix the PC.
Posted Thu 01 Apr 04 @ 11:33 am
Actuallly most of the 2 channel mixer have a way to convert a phono in into a line in, which makes them a virtual 4 channel mixer (4 channels plugged into the mixer, but you can mix only 2 at the same time). Change to emergency channel by switching between CD/phono on the table.
Posted Sat 03 Apr 04 @ 9:11 pm
here's another reason to use an external mixer:
try to slide the volume sliders rapidly on your console, you'll notice a small latency.
small, but just enough to decide to use an external mixer.
btw: if you record into mp3 using the built-in option of VDJ, you'll also notice that both channels are recorded simlutaniously including pre-listen and cueing actions (pitty).
you can work around this by doing your recording using another util like soundforge or wavelab form the line-in connected to the main output of your mixer. It works for me :]
to make a long story short: i'd advice you to use an external mixer.
Posted Mon 05 Apr 04 @ 9:30 am
