hie
i tried to install a trial version of virtual dj 3.1 and i expirienced the following error after installation
when i tried to run it i got an error message that said that the following file was missing
"dynamic link library DINPUT8.dll"
i tried to download it four times and still i got the same error.
can any-one help me to get this file as a lover of virtual dj i need to try out this version your help will
be sincerely appriciated.
Posted Wed 21 Sep 05 @ 10:19 am
I'm not sure if it's the right solution, but try installing the new direct x drivers for you graphic card. Since VDj 3.0 (or 2.1, not sure) there is a use of DirectX 8 or even 9 library requiered to display graphics properly.
Regards
Regards
Posted Wed 21 Sep 05 @ 1:37 pm
