Topic: sound card and setting up question
Posted Tue 20 Sep 05 @ 6:35 pm
buy a MAYA 44 it will handle the job well, and for TCV they can take like 3 weeks for delivery. Oh course you'll need a full license also
i know about the maya 44 but this is the sound card that i have can i use this with the time coded vinyl or do i have to buy the maya 44 thanks inadvance for your help
also can i set this up before i buy the software with the free trial to get the actual feel of it before i commit to buying
That soundcard you point, only works for use as standar soundcard, but not with TCVs. Read this post:
https://virtualdj.com/forums/41161/Hardware_Technical_Support/Audigy_2_ZS.html
The TCVs take from 2 to 4 weeks to get at your home. I use SL-1210MK2 so it will works fine for you as works for me. You must buy VDJ Full to work without issues.
The Maya 44 USB is cheap and it runs very well with VDJ. I use an Audigy 2 ZS Platinum, it works, but I pay $90 more and I don't be able to campare with a Maya 44 'cause I can buy it in Mexico.
thanks for your help so i am better buying the maya then for no problems
