Hey I am having trouble installing my maya 44 usb sound thingie.
Once installed (I believe correctly but likkely not) I only see something that says "Maya 44 Control Panel" Dhouldnt it say "Asio USB Control panel" ??? as a result of not havig what I believe is the right control panel I can not tweak any setrtings, all i see are 8 volueme bars:
Monitors input 1 and 2 3 and 4 Input with 2 volume bars and Out with 2 volume bars
can someone help any tips would be suggested.
also anyone willing to walk me through setting up virtual dj?
i have the numark TTX turntables (they are tanks) a behringer djx700 mixer and the timecoded virtual dj vinyls.
any help would be appreciated.
thanks
thanks
Posted Sat 17 Sep 05 @ 9:56 pm
          disregard my message I sorta figured out my maya usb problem...now if i can only get this whole thing working!
    Posted Sat 17 Sep 05 @ 11:37 pm
Good Luck Lloyd, enjoy the limited expirence. Hope could buy your VDJ Full to get the full beneficts of this great product.
Posted Sun 18 Sep 05 @ 1:29 am
          i'm fully registered come on now baby!....still working out some kinks in it though...can ya lend a hand?
    Posted Mon 19 Sep 05 @ 12:25 am
          Congratulations... let me know and  I help you if I can, sure!... See my blog to some useful info for TCVs...
For TCVs:
http://www.virtualdj.com/blog/acw_dj/
For the maya:
http://www.virtualdj.com/blog/dams/image3.jpg
    For TCVs:
For the maya:
Posted Mon 19 Sep 05 @ 4:55 am
          Hi, my setup for technics 1200s works great, however, my setup for cdj1000 has the same problem as this post.
I am using the following
2 Pioneer CDJ1000
Maya 44USB sound card
Stanton SA-3 mixer
Laptop
TCCD
After i hook everything up, and turn it up, play a song, there's no sound coming out.
checking the "time code vinyl configuation", i see it say no signal, but the graph shows extremely large signal. i was able to hit play button on cdj1000 and the needle arm on virtualdj would move to play, so basically i can control the playing and stopping of the music, but just no music is coming out.
did anyone get TCCD to work on CDJ1000? any advice would be appreciated.
Jas
2 Pioneer CDJ1000
Stanton SA-3 mixer
Laptop
TCCD
Jas
Posted Mon 10 Apr 06 @ 7:58 pm
          If signal is extremly large try to lower the signal of TCCD with audio editing programs and burn it again. It helped several users.
    Posted Mon 10 Apr 06 @ 8:30 pm
          Hi,
I had the same program the other day when I got my new Maya 44. I fixed it by turning the volume down on the Maya control panel to around the quarter level.
That gave me 100% signal. Try that and it might be OK.
The only thing then was that I had a loud whine coming out of the sound output when I connected to amplifier.
I fixed this, thanks to excellent quick VDJ support staff who told me I had to mute the monitor input of the Maya 44. Just click on the mute button.
Hope this helps and if I'm right off track please take no notice of me. I really like the Maya now.
Asymptote
Asymptote
Posted Mon 10 Apr 06 @ 11:08 pm
          had the sameproblem with the maya.
my solution: unplug the maya usb and plug it back in.(in my case though)
Posted Mon 10 Apr 06 @ 11:42 pm
          thanks guys, i'll give them a try and update back.
jas
    jas
Posted Tue 11 Apr 06 @ 7:25 am
          Here is the update.  I used Audacity to lower the level of the tccd mp3 and it fixed the prob.  now the wave form comes out in good range.  Thanks xeon for the tip and others for the help!
jas
    jas
Posted Fri 14 Apr 06 @ 9:15 am
          Some cd-players has too high output :)
even if you have inputs of maya44 at minimum, there is still problem.
nice to see you solved the problem ;)
Posted Fri 14 Apr 06 @ 12:18 pm
          yes was very excited to hear that nice sweet sound coming thru ;)
still need to tweak the tccd mp3 level a bit to make it optimal. good thing cdj1000 takes rewritable Cds or else gonna be a lot of waste.
j
j
Posted Fri 14 Apr 06 @ 6:07 pm
          Hi
Glad it's OK now - Thanks for updating us.
Asymptote
Asymptote
Posted Fri 14 Apr 06 @ 8:21 pm
          ACW:
Why is your setup up so different for the http://www.virtualdj.com/blog/dams/image3.jpg and the advanced setup on the website?
Posted Sat 15 Apr 06 @ 4:41 pm
          "The only thing then was that I had a loud whine coming out of the sound output when I connected to amplifier.
I fixed this, thanks to excellent quick VDJ support staff who told me I had to mute the monitor input of the Maya 44. Just click on the mute button. "
another update, i had this same problem as well where there's a humming coming out when hooking up to an amplifier. after muting the monitor input of the Maya44 ASIO setting, the sound is cleared. thanks asymptot for the tip!
jas
jas
Posted Mon 17 Apr 06 @ 2:00 am
          No Probs dj bobojam
Still like my Maya ;)
Posted Tue 18 Apr 06 @ 12:09 am
