hello, i was trying the vinyl bypass and got it to work, but the sound coming through is a bit muffled. also the level indicator on the mixer is low. just wondering if the sound card is not outputting enough power or what are the possible problem? the vinyl output fine if i connect turntable directly to the mixer. but when i connect turntable to maya44usb, and from maya44usb to mixer and did the bypass, the sound comes out muffled. any help would be appreciated.
j
j
Posted Wed 14 Sep 05 @ 5:00 am
I've tried the timecode bypass and it doesn't sound good in my opinion. My recommendation is to use Y adapters on your turntable outputs if you have the extra inputs on your mixer.
Posted Wed 14 Sep 05 @ 5:34 am
The easy solution is to keep the MAYA 44 USB control up, when you are ready to go to real vinyl, increase the input volume. Now becareful not to let your timecode signal go to low. when you mix out lower the input level.
I say just burn everything.
Posted Wed 14 Sep 05 @ 5:36 pm
