is it possible to sync 2 sessions of vdj on 2 different through a network??? as if i were to control the mixing on either pc, and broadcast/record from either one.
Posted Tue 13 Sep 05 @ 9:58 pm
You can only record/broadcast from one instance
You have to use the line-in to get back the real sound if you really want to use 2 instances
Posted Wed 14 Sep 05 @ 1:50 am
i just had a crazy idea if you could tag team dj from 2 pc's but both using the same multi-instance
Posted Wed 14 Sep 05 @ 2:04 am
I have VDJ installed on my laptop I use for Djing, and my desktop PC at home. I've got them networked, but now what ???
I can't find any instructions anywhere on what I'm supposed to do to get them to "see" each other?
The only thing I have found which is no help at all from the manual is:
"Network
If you want to use more than two instances, or if you want mixer with several at the same
time, you can synchronize several VirtualDJ between them thanks to OSC protocol."
"Network
Posted Tue 25 Apr 06 @ 1:09 am
