HI..
I'v bought Decks pakage and i dont know how to connect it to the computer and use it with virtual dj could you tel me what i need and how to do it or if it's writen somewhere could you tel me where it is so i can find out!
TANX
TANX
Posted Mon 12 Sep 05 @ 8:24 pm
Not sure what the decks package is but if you're talking about turntables or CD players here's the info.
https://virtualdj.com/products/timecode/
Posted Mon 12 Sep 05 @ 9:05 pm
If you need more info please you can ask it to us.. Thank you
Posted Tue 13 Sep 05 @ 10:10 pm
Tanx for help, i meant by decks pakage was 2 turn table and 1 mixer.i saw that link iand it was helpful.if you thing i need to buy something could you plz let me khnow.
TANX again.
TANX again.
Posted Thu 15 Sep 05 @ 7:55 pm
If you have two turntables and a mixer and you want to connect them to VDJ. You probably are trying to setup a TCV (Time Coded Vinyl) system. In this case you'll need a sound card with enough inputs and outputs. The Maya44USB is a good choice. The link above will help you sort it all out.
Posted Fri 16 Sep 05 @ 12:30 am
