Forum: Old versions
Topic: 3 small problems
hi
i have three smalll problems that i need help with
1- internal data base corrupted : i started getting the message recently vdj still works fine but every time i load it i get the message ( why am i getting this and what should i do about it )
2- when i search HD for mp3's vdj crashes could this be because of a corrupted file ?? and how can i find it ?
3- the loop is great but when u decrease the loop ( 1 then .5 then .7 ) it still loops but its kinda jumpy loop and its not uniform i mean it'll loop .7 and keep on doin that but it'll jump alittle and then go back to the original place and then jump a little and so on
i hope its not 2 much 2 ask
thanx in advance
dj smokey
Posted Mon 22 Mar 04 @ 3:15 am
answer to question 1 is to delete the internal database in the vdj folder which means loss of all bpms etc so you should always backup your database
well i solved 2
and walkers solved 1
what about 3?????
ps. walkers i still didnt delete it but the bpm and all the other stuff still show and the software runs perfectly is that normal??
maybe the corruption was solved when you found the dodgy mp3?
