JUST GOT THE HERCULES AND VIRTUAL DJ EVERYTHIN WRKS FINE, BUT JUST NEED SUM ANSWERS TO SUM OF MY QUESTIONS.
Q1 CAN U CHANGE WHICH FX U WANT TO USE WID THE HERCULES AS THE BASIC ONES ARE TO SIMPLE FOR ME.
Q2 CAN U TRIGGER THE HERCULES TO PLAY THE SAMPLES
ANY HELP WOULD APPRECIATED
Posted Tue 16 Aug 05 @ 4:00 pm
Purevibes welcome to this community.
At first please detect your console here: https://virtualdj.com/fusers/modifuser.html
Please don't shout (write all in caps lock/upper case)
Please write it correct english since many of us are not native speakers and it is hard to understad sometimes the play with words... It took me a while while I understood that sum is not a summary but "some". You will probably get faster and more exact responses in the future this way.
And now to your questions:
1:
There are setting in the virtualdj that allows you to assign different effects. Maybe you can download some effect for your (older) hercules version here: https://virtualdj.com/addons/view.html?type=effect%20plug-in but many are only for full version users.
2. there's a trick when you set your hercules to send midi commands, and let virtual dj respond to it.
This way you can map for example the effect buttons to play the samples. but you will lose effects as no effect can be loaded in order to not have "double action". This is hovever possible in the full version only.
1:
Posted Tue 16 Aug 05 @ 4:24 pm
