looking for some advice on sound cards, goin to be usin a external mixer, do i need 3 channels ie.channel 1= deck 1,channel 2 = deck 2,channel 3 = samples or does the samples mix themself before they leave the pc if you know what i mean
so to use the 2 decks and the samples would the soundblater live external card do?
any help would be much appreciated
Posted Tue 16 Aug 05 @ 3:26 pm
You can choose which channel will be samples send to. Any soundcard with 2 stereo outputs will work great with external mixer.
Dj Nikki
Dj Nikki
Posted Tue 16 Aug 05 @ 9:19 pm
are you planning on getting turntables in the future? if you do plan on getting tcv's then you will need 4 in 4 out, maya 44, or delta 44 are the best ones for that... if you just want to use a mixer, and dont plan on ever getting turntables, then i think anything will work, but im not sure
Posted Tue 16 Aug 05 @ 9:21 pm
nope no turntables for me, i`m just looking for a cheapish soundcard to play deck 1, deck 2 and the samples into an external mixer
Posted Tue 16 Aug 05 @ 10:38 pm
all you need is two stereo outputs, but i think it might work with one, if you use a slpitter...
Posted Wed 17 Aug 05 @ 2:29 am
