My friend asked me to get help again with broadcasts, it was working fine for him until one day when people now try connected the only get 10-20 seconds of broadcasts and then it just stops
can anyone help me ?
Posted Mon 15 Aug 05 @ 2:54 am
hey! i got the same problem, dont no how to fix it tho
Posted Mon 15 Aug 05 @ 3:07 am
wait! maybe he should lower the kbs
Posted Mon 15 Aug 05 @ 3:08 am
I have lower my kbs to the lowest still cut's out
Posted Mon 15 Aug 05 @ 3:11 am
then im sorry i dont no wat could be the problem
Posted Mon 15 Aug 05 @ 3:12 am
it worked fine before which is a bit nippy now he wants to make a radio station he can hardly do it when connection cuts off
if u work it oot contact me bren
Posted Mon 15 Aug 05 @ 3:14 am
k
Posted Mon 15 Aug 05 @ 3:30 am
Maybe it won't cut out if you by the FULL VERSION.
Just a thought, maybe it's a feature of the demo when you try to extend it's life.
Posted Mon 15 Aug 05 @ 10:35 pm
that's not true,i'm haveing the same problem cut's of after 2min i got this orther software i use and it never cut of and broadcasting 24/7 this is something supprt need to take a look at.
Posted Mon 15 Aug 05 @ 11:09 pm
are people connecting to you are are you broadcasting to server?
Are you behind NAT/firewall ?
try to connect 2 computers in the same network if it works.
This way you can confiorm if this is a problem of routing or problemof vdj probably.
You can even listen to vdj from winamp on the same pc as VDJ is running.
Posted Tue 16 Aug 05 @ 2:51 pm
i ran it to my other computer, in the same network, and it stopped after about 35 seconds this time
Posted Tue 16 Aug 05 @ 7:08 pm
hmm try to listen it on the same pc
Posted Tue 16 Aug 05 @ 7:47 pm
yep same thing stops after like 30 seconds
Posted Tue 16 Aug 05 @ 8:14 pm
my full version played ok for over 16 hours and still is...
what about those full version users that had problems, did you try to listen from same pc too ?
with same results as brennan ?
Are you sure no NORTON things and FIREWALLS or whatever "security" tools are not running ?
Posted Wed 17 Aug 05 @ 12:03 pm
My friend has the full version, it's not the firewall or anything to do with security
if u put winamp on repeat track it will re buffer the broadcast and work but what good is that when you only get 20 seconds of music my friend is trying to host his own radio station listers are waiting on the correction
plz help soon
thanks
plz help soon
thanks
Posted Wed 17 Aug 05 @ 2:41 pm
People are connecting to him
he now has a router so maybe that
Posted Wed 17 Aug 05 @ 2:59 pm
What is yor friends user name?, it would be best that we deal with him directely?, or is your friend called RAFF??.
Posted Wed 17 Aug 05 @ 3:14 pm
when he wants to have radio station he is on the internet right ?
Perhaps he can enbale netmeeting remote desktop, remote assistance or VNC. And I can have look at it.
Just make it possible
Posted Wed 17 Aug 05 @ 3:30 pm
i think if it connects and then drops it might be a setting in the router blocking the WAN
Posted Wed 17 Aug 05 @ 4:35 pm
al have to find out his user ID .....
Thanks for the help, i have told him to enable these ports in the routers virtual server
his WAN is different to the address user tune in 2
Posted Wed 17 Aug 05 @ 5:08 pm
