Forum: Old versions
Topic: Problems with .m4a
i need to play some .m4a in the virtual DJ but i cant
Have u seen a codec or something like that?
Thkz
Sorry 4 my english
Posted Sat 06 Aug 05 @ 7:22 pm
install either itunes, or quicktime in the newest versions. Then click on the extensions tab make sure mp4a is pointed to the quicktime decoder. Also if you bought these tunes from itunes they will not play in virtual dj because they are encypted and they will only play in itunes.
on second thought
2.05 didn't have the function however 3.0 does, go here virtualdj.com/purchase to fix the problem.
