I cant get any downloaded skins to work i do not know whats wrong so i cant tell u guys anything more.
i Would love to use the multi instance skin that would be brilliant but i cant :(
Thanks in regards
Thanks in regards
Posted Fri 05 Aug 05 @ 1:11 am
First, what version of vdj are you using. did you upgrade to the version 3 or stay at 2.6?
what internet browser are you using to download the files.
What do you do with the downloaded files when you want to use them?
Posted Fri 05 Aug 05 @ 1:27 am
3.0
i didnt really undrestanded the question but if it helps i downoaded it from a mac and then put it onto my pc
Put them in the skins folder but i cant see them in vdj skin options
Posted Fri 05 Aug 05 @ 2:02 am
you mean you put them in VDJ skin folder.
is the file name of the skin files exactly like this: skinname.zip?
if it isn't then there is a problem with the extension.
Maybe if you try downloading the skin directly from a windows computer.
Posted Fri 05 Aug 05 @ 3:04 am
alright i got it kickin but i cant pull the lower instance of vdj so i can just look at one at a time.
ive tried to fix it but i cant help:)
Posted Sat 06 Aug 05 @ 3:31 pm
