I found the program on my computor and want to use it to 'mix' files so they could be converted to use in Flash (which accepts .mp3 and .wav) from windows media files, Is there any way I can do this?
Posted Tue 05 Apr 05 @ 8:52 pm
Ola,
Can't remember if the Demo version supports Recording while u mix, but if it does, it will record to a wav file, which personally I would convert with a 3rd party converter to mp3 first, (file size reasons) before importing into a Flash project.
That help?
DJ Jamie
...out o good ol RSA
That help?
DJ Jamie
Posted Wed 13 Apr 05 @ 1:16 pm
