After having spent 80 minutes mixing and recording using Atomix. I went to listen to the Wav. file. Only to discover that i had about 20 wav files of the session I recorded. Each one contained pieces of the 80 minute recording session. And they play as individual files. Why did it do this? I wanted one wav file not a whole of small individual little files. I'm really disgusted with the time I wasted tonight. I've used this program before and never had this recording problem. What gives? I'm really mad.
Posted Sun 27 Jun 04 @ 1:30 am
Probably because you have activated the "auto cut" option in the "record" window.
I think you can save your mix by burning them on CD and by disabled the 1 sec blank between each track in the option of your burning program
Coyote
Coyote
Posted Mon 28 Jun 04 @ 12:05 am
Thanks I did have that activated. Will try it another time.
Posted Tue 29 Jun 04 @ 1:12 am
