Forum: Old versions
Topic: Sound Problems, AGAIN!!!
sjohnPRO InfinityMember since 2004
OK. I'm very close to trying another DJ program, but will try to straighten out my problems first. I had a wedding tonight and again had sound problems about 2 hours into the event. The sound was distorted and I also noticed the Virtual DJ program begin to slow down. When I looked for songs in my folders on the left side of the player, it started getting noticably slower. I finally resorted to cd's, thank God I brought backup equipment, and then rebooted 2 times and everything seemed fine.
My laptop is a brand new toshiba P4 2.4 ghz with 512 ram. I also use a Gigaport soundcard. I honestly think it's the program. I also use the basic skin. Anyone having this issue? Anyone have a resolution?????
Thanks,
Scott
Posted Sun 07 Mar 04 @ 4:24 am
Did you have any other programs running in the background, like a antivirus program, or were you connected to a network/internet?
If so, that might have been the problem. One should always close or exit these programs, so that they don't suddenly use up CPU time, like when a antivirus-program starts its weekly scan or someone is transfering files to/from your computer.
I hope this helps.
- Jim Nordic
Posted Sun 07 Mar 04 @ 4:38 am
Also check if the ventilation of your laptop is free from any obstruction (in and out). A laptop which overheating can have this kind of problem.
Hope this help
Coyote
Posted Sun 07 Mar 04 @ 5:04 am
Is the laptops fan suppose to stay on all the time? My kicks on and off. It's located on the bottom of the laptop and clear of any dust. It's only a couple of months old.
Thanks,
Scott
Posted Sun 07 Mar 04 @ 3:51 pm
HomeboyPRO InfinitySupport ManagerMember since 2003
I also use a toshiba laptop. Is yours a satellite ? Anyways my sound never becomes distorted but it does get very hot and after about 3 or 4 hrs it can be a little choppy. I think if I added more ram there would be no problems at all.
Posted Sun 07 Mar 04 @ 7:44 pm
i have the same thing happen to me recently , maybe i have to many things save to my hdd, idk maybe slowing my pc down .. idk , any1 figure out whats the deal?
Posted Thu 11 Mar 04 @ 4:26 am
i had the same issue on a Dell Inspiron 8100 256MB 1 GHZ.
it works allright for several hours, then it becomes choppy.
i don't want to buy another memory expansion bank because the slot has already been taken by a 128mb bank.
Because i don't wnat these surpises anymore, i built myself a brandnew workstation for @ home, and promoted my current workstation to 'Dedicated VDJ-station' and added a tft-screen.
no worries anymore :]
Posted Thu 11 Mar 04 @ 1:32 pm
nancybPRO InfinityMember since 2004
Hi, I also have 2 brand new Toshiba p25 & p15. The cooling is set to high but after an hour or 2 I also get that distorted sound. Technical support suggested I disable the limiter. I tried doing so when the sound started distorting and the system let out a huge wierd sound so I haven't tried it live again...I'm going to try turning it off when I start out...
Posted Wed 17 Mar 04 @ 1:46 am
DJFREDOPRO InfinityMember since 2003
I have a Toshiba Satelite Also, As for the software slowing down, I have not had that problem since I turned off the Hyper Threading in my Bios. Try that. Also I also got sound issue after 4 to 5 hours of straight play. If somebody has played with the limiter disabled I would greatly appreciate it if you'd let me know how it went with your sound issues.
Posted Thu 18 Mar 04 @ 12:11 pm
Hmmm I wonder if I have hyper threading I don't believe I do.
Posted Thu 18 Mar 04 @ 9:44 pm
keyonPRO InfinityMember since 2003
I don't know if this will help anyone with continued Toshiba Satellite sound problems: I had distorted sound with vdj too until I went from 512 to 767 mb memory and changed the page file. I have a thread on this posted here under 'warbled sound.'
Also, when I first bought it I learned that the usb bandwidth on my Toshiba laptop (nearly a year and a half old, 1955 Satellite series) wasn't enough for usb sound cards -- caused hiccups, skips in sound til I went with an external pcmcia sound card which solved that problem.
Posted Fri 19 Mar 04 @ 10:40 pm
Hello new to this but love it!!! Well done... however I get a wobble pitch up/down when using sometimes... any reason HELP!!!
Thanks Mike
Posted Fri 19 Mar 04 @ 11:07 pm
RAM
Posted Sat 20 Mar 04 @ 8:52 am
Hi,
I have the distorted problem and have a brand new toshiba p25 609 1 gig ram..hmmm, maybe the computer is not the problem. Software glitch? Controller glitch?
Posted Wed 24 Mar 04 @ 2:00 pm
Nancyb,
Do you have Hyperthreading and/or speedstep on your laptop? try to disable it.
another tip that solved my problems:
Keep your windows-XP up to date, there are several M$-Hotfixes (including USB-drivers and Direct-sound drivers etc) which solves most of the problems.
I have build myself a dedicated PC for mixing ony.
There's Window's XP on it incl.SP1 with all the latest hotfixes.
It's got a Asus A7N8X-E-deluxe mainboard (AMD 3000)
1 GB ram pc3200(DDR400)
only 1 HD of 80 GB (internal)
I only use it for Mixing and nothing else, there are 2 software packages installed: Winamp(for CD-ripping) and VDJ.
It really runs like lightning and still keeps running without any problems/distortions/interruptions even after playing 3..4 hour sets.
Posted Fri 26 Mar 04 @ 7:13 am
