Hi
I just got the demo and are intrested in buying ..
but I have noticed that in general the "sound" is
not that good .. almost got a hollow type of sound
and that when U beatmix it does not have that sharp sound
on the beat , like some other popular mixing programs have .
basically .. it does not have that " mixing a vinyl " sound like
virtual turntables have .
are there are setting to correct this ? or does it always sound like that ?
Posted Fri 12 Mar 04 @ 9:37 am
Yes it is.
Disable the Master Tempo from the settings.
This will help, but when you pitch more than 8 BPM up or down then the vocals begin to go a bit strange.
Posted Thu 05 Aug 04 @ 11:29 am
Sometimes the sound is not very great depending on what you are mixing and the quality of the MP3 you are using. I try to avoid using downloaded mp3's since their quality tends to be poor and I. Try to upload my music from cd's converting them into mp3 at the highest quality possible; 256kbps or higher. For the finishing touch when burning cd's I use RealOne and use the Equalize volume feature built into the burnere to balance out most volume discrepancies.
But thats just me :-D
Posted Sat 04 Sep 04 @ 2:06 pm
