im goin crazy over this skins!!!
the only skins that work on my computer are the 800x600 ones.. how can other people use the 1024x768 skins??? do they have a different atomixmp3? and how can i get a 1024x768 skin to work on my atomix?
i tried to use them but the skin is partially displayed on the screen and the program gives me an error and quits :-(
pliz sumbody tell me wot to do... there's the cdj1000 skin and i cant use that makeS me CRYYYY oh man
leo
leo
Posted Tue 02 Sep 03 @ 1:43 am
Sounds like you need to chnage your screen resolution!
Posted Tue 02 Sep 03 @ 2:02 am
i did change my screen resolution but the atomix window looks smaller (of course) and i still get the error and the application quits.
i tried having a res of 1024x768 res and load a 1024x768 skin, the skin looks like the windows cant fit it all and the programs stop running.
i can only use 800x600 skins in my computer, and they work no matter what my screen resolution is.
i tried loading the skins with atomix in full screen, but it doesnt solve the problem. i think that when u load a bigger skin, the window has to enlarge so it can display the whole thing, right?
i dunno wot to do
i dunno wot to do
Posted Tue 02 Sep 03 @ 11:11 am
are you using the last version?
Posted Wed 03 Sep 03 @ 3:41 pm
i use atomix v2.2
i just wanna get the cdj1000 skin to work..sigh
Posted Sat 06 Sep 03 @ 10:08 am
if there is somebody that can help me....
PS : I HEARD that if ur a demo user u have to change the names of the skin files (both xml and bmp) to default is it TRUE???
Posted Sun 07 Sep 03 @ 1:06 pm
just tried.. doesnt work..
Posted Sun 07 Sep 03 @ 1:08 pm
What kind of videocard do u have?
And are u using the latest drivers for the card?.
Maybe it helps.
Greetz
Bacoo
Maybe it helps.
Greetz
Bacoo
Posted Wed 10 Sep 03 @ 2:07 pm
doesnt help..
looks lyk that if i wanna use a skin it has to be a 800x600 one.
that sucks.
in virtual dj i can use all kind of skins, the program automatically resizes the window and the skin is displayed properly. but in atomix when i choose a bigger skin, the window doesnt resize, and the skin isnt shown properly.
everybody here can use any skin ye? whatever resolution it is u can use it ye? why can't i? :(
HELPPPPPPPPPPPPPPPPPPPPPPP
that sucks.
Posted Sun 14 Sep 03 @ 11:41 am
And you're sure that you are using the latest demo version? The bigger skins didn't work with the earlier versions.
Posted Sun 14 Sep 03 @ 4:08 pm
have you pressed the maximize button on the skin?
Posted Mon 15 Sep 03 @ 4:28 am
problem fixed .
thanx everybody the problem was that i had atomix v2.0
i downloaded the trial version v2.2 and skins work now.
thanx any1 i really found this forum useful.
im proud of atomix, im proud of this site and im proud of youse all. (relax..)
leo
leo
Posted Sun 21 Sep 03 @ 2:52 pm
so maybe you have to think to buy this program:)
Posted Sun 21 Sep 03 @ 9:22 pm
Is their a way to resize the virtualdj window so that it doesn't take up the whole screen?
Posted Fri 19 Dec 03 @ 5:36 pm
