Hi,
Can't get it to work right. When I do, it is so distored and/or the music stops a second and makes a high pitch noise. I have a PC with amd 2000, XP, 80g drive, 5132 ddr ram and a onboard sound card, wave '97. I added a SB live I think its a 5.1. If I use the SB card on its own in 3d, it works but the music stops a second and makes a high pitch noise. Does this with the 2 card, speaker, headphone setup too. I have the control panel set at quad speakers.
Thanks I really would like to use this program. I might be better off going back to the demo? Not as many problems.
Andy
Andy
Posted Mon 11 Aug 03 @ 8:54 pm
mabe you have a problem with your system BIOS
Posted Mon 18 Aug 03 @ 7:54 pm
