Hi, I'm a newbye. My name is Diego.
I find that AtomixMp3 is a wonderful software...i tried many dj software because i'm starting and i've found that noone is so simply and garanties so good results.
Please help me with this problem..
I have only one sound card...but it is a Sound Blaster Live (in the back there are five jacks black, pink,green,blue and another one). I wanna make a mix longer than two songs and for making loops of the next song i need to use headphones.
Is it possible to use both speakers and headphones with one sound card?(remember that it is SB LIVE). If possible please tell me what i have to select in atomix or what software i need to install, and in where jack i must insert speakers and where headphones...so please tell me all i need to do to "use both speakers and headphones with one SB LIVE".
Thank you before for you're answers...i hope you answer soon.
Greatests
Diego
Greatests
Diego
Posted Fri 11 Jul 03 @ 8:05 pm
Yes, you can use AtomixMP3 in dual-output mode with a SB Live.
But you need to purchase the program, as the demo does not allow that.
Posted Fri 11 Jul 03 @ 8:32 pm
how do you do that with sb live??????
i have the same soundcard....
Posted Fri 11 Jul 03 @ 11:22 pm
As he said... as a demo user you don't have the sound configuration options available to you. In order to achieve the dual outputs you must purchase the full version.
Posted Sat 12 Jul 03 @ 1:13 am
I have the full version....!!!
you wont take my email so i giveup trying to be a fulluser.
dimitri.....
dimitri.....
Posted Sat 12 Jul 03 @ 5:19 pm
Update your profile and insert your serial number. @
Posted Sat 12 Jul 03 @ 5:23 pm
YES YES!!! Ihave done it!!!!!
it's 2 mono channels i am getting????
(i have 1 soundblaster live)
Dj Dimitri
Dj Dimitri
Posted Sun 13 Jul 03 @ 3:08 pm
DJ Dimitri, please contact service@atomixmp3.com and provide your serial number to have your account upgraded.
Posted Tue 15 Jul 03 @ 4:09 pm
