I know I'm a demo user. I was just curious as how would one connect an external mixer to work with AtomixMP3?
There is no instructions on putting that together.
To the Atomix people. Can you create a better set of instruction/manual for your product. Although I'm aware that it's an easy program to use but you got to do better with the manual and explain the functionality as well as any 3rd party product like adding a mixer and such in more detail.
Posted Fri 20 Jun 03 @ 3:29 pm
Hi. You can use the search function to find more about it. It has been discussed many times already.
Posted Fri 20 Jun 03 @ 4:44 pm
OK, Thanks for the info.
Posted Fri 20 Jun 03 @ 5:17 pm
