Does anyone have any knowledge on writing device drivers for usb type hardware. Thanks
Posted Fri 04 Apr 03 @ 2:37 am
Man, you guys are serious about this !! LOL !!
Posted Fri 04 Apr 03 @ 2:38 am
yep. Was searching the internet last night seems USB type mouse controllers all work on 5v logic
So basically like ASCII if each button is given a binary code associated with it can be done. I think things like pitch slider and spinning scratch thing would need Analogue to Digital converter circuit which isnt too difficult. Problem is with the decoding at the computer end needs knowledge of drivers. USB only has four wires one +5V one earth and two data transfer wires. I
So if audio cards were integrated into controller would need one data in and one data out.
Could work?!
Could work?!
Posted Fri 04 Apr 03 @ 8:14 pm
