Hi
I have a big problem- when I play a song and then try to play another one to do a mix - it puts on the beat lock. I don't know if that's the real name of it - but it sure is a rel problem.
I DON'T WANT THE SONG TO START WHEREVER THE PROGRAM WANTS!
Damn this VDJ is much harder than the Atomixmp3....
PLZ HELP ASAP, how can I cancel it?????
Posted Wed 11 Feb 04 @ 9:29 pm
you are in auto-play mode. VDJ mix all
The manual mixing , mixing with the beat-lock and the auto-mix are 3 different thing
plz read the manual
https://virtualdj.com/support/Virtual%20DJ%20-%20User%20guide.pdf
plz read the manual
Posted Thu 12 Feb 04 @ 6:47 am
No man... I'll try 2 explain it again-
the right deck is playing, ok? good
the left deck has a song ready on it.
when I press "PLAY", it's like the VDJ is sychronizing both songs.
I mean - the song isn't moving "Free", the program "puts" the song only on the beat.
Sorry for my lame English, anyone here talks Hebrew?
Oh - and I do know something about this program, it's not the first day i'm using it...
Posted Thu 12 Feb 04 @ 2:23 pm
it just sounds like you have the beat lock button pressed and VDJ is trying to line up the beats of the songs automaticaly. check to see if this is on (it also sounds like you might have the Beatlock engin set to "elastic" rather than the default "rigid")
if you are using the DJ Console make sure the beatlock button is not stuck in
Posted Thu 12 Feb 04 @ 11:20 pm
