I'm trying out the demo, and it seems the gain gets wacky sometimes. Is this a "feature" of the demo?
Also when I start it up, is there a way to prevent the volume going to 100%?
Posted Sat 22 Feb 03 @ 5:07 am
No the gain sucks!!!.
In the 2,5 years that i am using atomix the gain got better, but it still sucks.
To make it better scan your songs, and gain all your files with the free software GAIN.
Vote for a Dunamics Processor!
Dynamic Salva
Dynamic Salva
Posted Sat 22 Feb 03 @ 7:50 am
Yes indeed, to prevent your volume from going to 100% all you have to do is enable the multi instance in the settings window.
This will prevent your windows volume from going to 100% on launch of Atomixmp3.
Posted Sat 22 Feb 03 @ 8:02 am
If you want a better gain , you just have to modify the sensibility , in the skin (.xml)
This il the default gain:
.slider action="gain" chan="1" orientation="round" .dblclick="reset" rightclick="auto">
. size width="21" height="21"/>
. pos x="321" y="185"/>
. fader sensibility="200">
. pos x="286" y="1383" nb="19"/>
. over x="286" y="1404" nb="19"/>
. /fader>
. clipmask x="411" y="1228"/>
./slider>
at the line , " fader sensibility="200"> " remove the 200 and write 2500. And save it
The gain will be better.
mUd-V
. /fader>
./slider>
mUd-V
Posted Sun 23 Feb 03 @ 5:22 pm
Mud-V. This is just what I've been looking for, but can this be done in other skins like Darkfun? I don't see fader sensibility in them. Thanks!
Posted Mon 24 Feb 03 @ 2:57 am
abnorm, you just have to modify or change the skin !!
mUd-V
mUd-V
Posted Mon 24 Feb 03 @ 2:40 pm
Mud-V, it worked great in the default skin but Darkfun doesn't have fader sensibility="200"> line in it. I tried adding it in but the skin wouldn't start after that. I am not sure how to modify the code for it to accept that line. Let me know if you can help.
Posted Mon 24 Feb 03 @ 7:26 pm
Ok nevermind that Mud-V. It will only work with circle sliders. Now I am trying to think of a way to ad a 3rd circle slider for this to other skins.
Posted Mon 24 Feb 03 @ 8:17 pm
