I have Atomix 2.2 running on my current computer fine. Recently, I built a second machine (with a faster CPU) for live gigs. The problem on the new machine is that Waveform (Visual Mix Window) in Atomix takes about 10 seconds or longer to fully show up on the screen, which is very annoying and slows me down. At first I thought it was the videocard, so I tried swapping them. Same problem occures...
Has anyone come across this problem? The only other difference between two machines is the motherboard with CPU. One is AMD 1.7GHZ, the new one is Intel 2.4GHZ.
Posted Fri 03 Jan 03 @ 12:24 am
in w2k?
Posted Fri 03 Jan 03 @ 8:33 am
I am running WinXP Pro on both machines. Works fine on one.
Posted Fri 03 Jan 03 @ 6:56 pm
If you have anything running in the background you might want to turn it off.....also in the set up section of atomix you might try turning off "Charts" if it is turned on.
Posted Sat 04 Jan 03 @ 11:48 am
It's a new system I just build running only Atomix. There is nothing running in the background and Charts are off. Maybe it's a setting in a BIOS? Already tried swapping video cards.
Posted Sat 04 Jan 03 @ 9:28 pm
I got this problem too, but only when I multitask too much.
Posted Mon 06 Jan 03 @ 10:01 am
There must be some kind of fix for this. It's a faster machine with nothing but Atomix on it.
Posted Mon 06 Jan 03 @ 10:12 pm
what is your Ram memory in the second machine?
Posted Tue 07 Jan 03 @ 12:58 pm
I had this problem on my old machine and even when i upgraded but it all sorted out when i baught some DDR Ram.
Posted Tue 07 Jan 03 @ 11:56 pm
It already has 512mb of PC2700 DDR RAM. :(
Posted Wed 08 Jan 03 @ 3:33 am
