I'm nog using Virtualdj Demo
but i have ONE problem everty thing works fine and ect
but i lag when the 2 turntabels turn aroud
is ther a possibilty to stop the turntables when music is playing
plz give me answer thx
grtz plut0r
if this works maybe i will buy Virtualdj ;)
grtz plut0r
Posted Fri 30 Jan 04 @ 7:13 pm
What are the specifications of your computer?
Posted Fri 30 Jan 04 @ 8:30 pm
500 mhz
64 ram
a 3d running on my ram : 60 mb ram & 4mb 3d
15 giga
btw win 98
not big system but in the summer i will buy a new pc but now i wanne test virtual dj
64 ram
15 giga
btw win 98
Posted Fri 30 Jan 04 @ 9:28 pm
First, you need more ram…Look here for the minimum requirement to run Virtual DJ correctly: https://virtualdj.com/features/description.html (at the bottom of the page)
But you can try to set the “maximum load” song at “nothing” in control panel, and also, you can try to disable all automatic functions…
Hope this help
Coyote
Hope this help
Coyote
Posted Fri 30 Jan 04 @ 9:57 pm
You'll definately need more computer to run VirtualDJ.
at least 512 of RAM.. twice that would be better... and at least a 1ghz processor. Best would be a p-4.
Posted Fri 30 Jan 04 @ 10:04 pm
Where can i find this " control panel " :s
Posted Fri 30 Jan 04 @ 10:20 pm
in the settings panel... look for a choice called "max load"
you can set it to none, but with your outdated computer, I doubt it will help very much.
Posted Fri 30 Jan 04 @ 10:25 pm
Well i will wait till i have a new pc then i will try
VIRTUAL DJ
i will use atomixmp3 now ;)
VIRTUAL DJ
Posted Fri 30 Jan 04 @ 10:35 pm
