Hi guys,
When I am using my DJ Console with the pitch, I have a problem with the precise mixing when it is for example 0,5%. The program Virtual DJ does'nt respond on this, only when I am using larger pitch for example 1,5% or higher
Anyone else with this problem,
Also the sound loudness isn't super, the power of the dj-console is really not hard. Really irritating when you have to use this option in Virtual DJ, because the sound isn't then so super!
But the console is super!!!
Posted Sun 18 Jan 04 @ 9:43 pm
Dont know if i understood you properly, but the pitch sliders of the console are somewhat unprecise. If you want to do exact beatmatching it might be better to use the mouse for last fine tuning.
Think i didnt understand what you mean by "loudness" ?
Maybe you specify this a bit more...
Greetz
Greetz
Posted Mon 19 Jan 04 @ 12:58 am
