Forum: Music discussion
Topic: How i solve the problem with the 16bit loop
first of all i loop only clear sounds like just melody or a vocal but i finger out that hearing the same stuff every 8 loops its kind of boring when you do long mixes like 3min two songs are playing and you just play with bass treble..etc you know what i mean.So i resolve my problem of that borring 8looped the same stuff in a very simple way.i just close the sound of the deck that is looped every 2nd 8bits so i got my looped deck sounds like its looped on 16bits.This trick will not work on complicated sounds i mostly use it with voices.adn dont put the level of your looped deck higher than your normal deck.
P.S. i dont feel like socrates:) it just came to me:) maybe its stupid idea but.....nevermind:)
Posted Fri 15 Mar 02 @ 11:44 pm
DJtalonHome userMember since 2001
Try the SmartRepeat effect plugin (once you get v 2.1 this weekend)... it should be fun for you :D
Posted Sat 16 Mar 02 @ 1:58 am
