Forum: Italian Forum
Topic: Nuove features
Ok e' un po' presto per la nuova versione ma e' possibile sapere, magari facendo una specie di classifica, quali sono le maggiori richieste di nuove features fatte per la nuova versione di Atomix?
Crazy Boy
P.S. io ci metterei pure la sync bpm per tutte le sessioni aperte di Atomix
Posted Thu 04 Jul 02 @ 10:14 pm
PerozPRO InfinityMember since 2003
Questa e' una lunga lista di new features (gia' inviata ai teamers) che ho compilato personalmente grazie sia a mie idee che a quelle che ho scovato in giro. Sono in inglese perche' e' l'unica lingua che conosco per comunicare con i teamers non italiani.
New ideas for Atomix:
- Master volume
- Master volume for effects
- Dedicated Volume for the headphones (without using gain’s turntable)
- Master volume for samples
- Pitch for samples
- Master pitch for samples
- Loop for samples
- Beatmatch samples with the song
- Random and loop for the whole playlist
- Reverse (effect)
- Loop for the whole song
- Left and right channel switch regulator (the distance between the right speaker, the listener and the left speaker couldn’t be the same: it’s my situation)
- Load more than 3 effects in the dedicated window. ...20slots? : )
- Link the multi istances pitches, volumes, gains or create a 3 channel mode (a,b,c) with recording support
- Possibility of a larger equalizer: 5, 7, 9
- Mic talkover with volume and some voice changer on the fly (robot, fly, kidnapper, exc.) with a dedicated equalizer and recording support
- Exit all effects button/shortcut
- Loop configurable
- Eq crossfaders shortcuts
- Id3v1 and Id3v2 tags compatibilty
- CDDB for titles and artists playing with CDs
- Video acceleration in order to use less 2d
- Pitch range: –100% to +100%
- Search: improve searching by artist, by song, by bpm, by path, by date
- Order files by date
- Midi compatibility
- Regulate the dimension of the spectrum analyzer or hide it
- Gamepad joystick support: you can give some functions to the joystick too.
- Shortcut settings window is not really easy to use. You should realize it like a video game controls window: only one window with all the functions. Here is an example:
FUNCTION SHORTCUT
Stop a Spacebar
Stop b Not assigned
Stop selected desk Not assigned
Stop desk in play A
- Choose wavs and mp3 samples in the same window (without selecting type of file: wave or mp3)
- View and set the crossfader’s diagram
- Listen the variation of the equalizer settings in the preview (headphones)
- Line in soundcard support: record from a physical mixer (with a button to cut between the songs) or insert another device (MC, CD, turntable, exc…). See x ripper : http://www.sonetics.net/software/xripper.html
- Give functions to the mouse’s wheel (scratch, pitch…)
- Preview the whole song during the play: I’m listening to the song in “a” (with the master) and I want to listen to the last part of it in my headphones (monitor) without inserting a copy of the song in the deck “b” and skip to the point I want to listen (in monitor) of the song
- Atomixmp3 should keep the same gain level of a song: it goes up and down, especially with (?) songs
- Extend scratching area or go forward/backward to skins that shows vinyls or jogs
- See the cue setpoints on the progress bar of the song (with a particular color)
- Dedicated button for eq crossfaders reset
- Read mp3PRO
- Buffer for mixing 2 songs from the same CD (is it possible?:)
- Hide equalizers in order to give more space to the browser
- Samples: insert one cue point setting: if you have an empty space before the sound, you can cut it.
- Samples: possibility of preview
- Samples: adjust the gain level: match it with the gain of the song
Si accettano suggerimenti e nuove idee naturalmente :)
Peroz
Posted Fri 05 Jul 02 @ 8:28 am
certo ke se le elencassi in italiano sarebbe meglio!!
nn credi peroz??
dai una bella....traduzione nn fa male....trova 5 minuti e falla!
CIAO CIAO
DJ FREESTYLER
Posted Sat 06 Jul 02 @ 6:13 pm
Tradurre tutto sarebbe troppo sbatti... :)
Non e' ora di imparare l'inglese?
Take it easy
Peroz
Posted Sat 06 Jul 02 @ 6:53 pm
Siamo nel forum italiano,mica in quello inglese...
-Volume generale per gli effetti;
-Volume dedicato per le cuffie (senza usare il gain della piastra);
-Volume generale per i campioni;
-Pitch per i campioni;
-Master tempo per i campioni;
-Loop per i campioni;
-Sincronizzazione della battuta dei campioni con la traccia;
-Possibilità di scelta dei brani a caso e ripetizione della playlist;
-Effetto reverse;
-Loop per la traccia;
-Selettore per la regolazione del canale destro e sinistro(la distanza tra l'altoparlante destro,l'ascoltatore e l'altoparlante sinistro può non essere la stessa:è la mia situazione);
-Caricare più di tre effetti in una finestra dedicata. ...20 effetti? :)
-Collegare insieme i pitch,volumi e gain nelle multi istanze o creare una modalità a tre canali (a,b,c) con supporto di registrazione;
-Possibilità di un equalizzatore più grande:5,7,9;
-Talkover del microfono con volume e cambiamenti della voce al volo con un equalizzatore dedicato e supporto di registrazione;
-Scorciatoia/pulsante per uscire da tutti gli effetti;
-Loop configurabile;
-Scorciatoia per i crossfaders dell'equalizzatore;
-Compatibilità con gli standard Id3v1 e Id3v2;
-CDDB per gli artisti e i titoli per i cd;
-Accelerazione video per usare meno 2d;
-Selezione del pitch +100% - -100%;
-Ricerca:migliorare la ricerca tramite artista,traccia,bpm,posizione,data;
-Ordinare i files tramite data;
-Compatibilità midi;
-Regolare la dimensione dell'analizzatore di spettro o nasconderlo;
-Supporto per il joystick: puoi assegnare alcune funzioni anche al joystick
-La finestra per il settaggio delle scorciatoie da tastiera non è molto semplice da usare.Dovreste realizzarla come la finestra di controllo di un videogioco:solo una finestra con tutte le funzioni.Ecco un esempio:
SCORCIATOIE PER LE FUNZIONI
Stop a:barra spaziatrice
Stop b:non assegnato
Stop piastra selezionata:non assegnato
Stop piastra a in play
-Selezionare i campioni in wav e mp3 nella stessa finestra(senza selezionare il tipo di file:wav o mp3);
-Vedere e settare il diagramma del crossfader;
-Ascoltare la variazione dei settaggi degli equalizzatori nel preascolto (cuffie);
-Supporto per il line in della scheda audio:registrare da un mixer fisico (con un pulsante per tagliare tra le tracce) o inserire un'altra sorgente(MC, CD, piatto, ecc…),guarda x ripper : http://www.sonetics.net/software/xripper.html
-Assegnare funzioni alla rotella del mouse (scratch,pitch);
-Preascoltare la traccia mentre è in play:sto ascoltando la traccia nella piastra "a"(con il generale),e voglio ascoltare la arte finale nelle mie cuffie(monitor) senza inserire una copia della traccia nella piastra "b" e saltare al punto che voglio ascoltare (in monitor) della traccia;
-Atomix mp3 dovrebbe mantenere lo stesso livello del gain di una traccia: va su e giù specialmente con tracce contrassegnate dal ?;
-Estendere l'area per lo scratching o andare avanti e indietro per le skins che fanno vedere vinili o jogs;
-Vedere i punti di cue nella barra di progressione della traccia (con un particolare colore);
-Pulsante dedicato per resettare i crossfaders degli equalizzatori;
-Leggere gli mp3 pro;
-Memoria buffer per mixare due tracce dallo stesso cd (è possibile?);
-Nascondere gli equalizzatori in ordine per dare più spazio al browser;
-Campioni:inserire un settaggio di punto di taglio:se hai uno spazio vuoto prima del suono,puoi tagliarlo;
-Campioni:possibilità di preascolto;
-Campioni:sistemare il livello di gain:sincronizzarlo col gain della traccia.
Penso che così sia meglio...
Per maggiori info chiedete pure,ok?
Dadegian
Posted Wed 10 Jul 02 @ 10:54 pm
Bravo Dade! :)
Peroz
Posted Thu 11 Jul 02 @ 1:36 am
