Forum: Old versions
Topic: Cant use headphone anymore - Page: 2
The simple but long term solution is to learn to beatmatch. If you create music you can count a beat. Should be natural for you pick it up and then practice a bit.
You will not have to find the BPM at all . Just stick them on and mix away. I hardly every look at the bpm display on VDJ (obviously a low track and a fast one will not mix).
With prctice you will be able to tell how much slower/faster a trach is after a couple bars. Believe me its much more fun :)
Posted Thu 12 Feb 04 @ 5:00 pm
nizorHome userMember since 2003
U're right, anyway. Practice is the answer. The only one.....
I'm just a little cockroach in a Hulk Hogan's combat shoes world.
Posted Mon 16 Feb 04 @ 10:26 pm
Havent we lost the thread here? It is supposed to be about the headphone probem. Does the the management know when an update will be available to fix this problem?
Posted Thu 26 Feb 04 @ 11:25 am
