Hello there,
I am experiencing the following problem,after playing for a few hours my sound level is going down slowly to approx 50% of the sound capacity then i have to shut down the computer wait for 5 minutes and restart the computer and then everything is again ok for a few hours anyone now what to do? the cpu is new P IV 3Gh disabled Hyper Threading 512 MB Memory(i use the hercules dj console)
Posted Tue 13 Jan 04 @ 10:46 pm
Strange problem!
Did you try to play music with winamp (for example) in the same way, to see if it's a software or hardware problem?
For me, it looks like an hardware one.
Posted Wed 14 Jan 04 @ 9:01 am
Try nudging the volume level back with the controller or your mouse. Can you physically see that the volume is set lower on a deck ? Also is it master volume at half or a deck ?
Posted Wed 14 Jan 04 @ 9:19 am
Have you checked the gain?
Posted Wed 14 Jan 04 @ 3:50 pm
I have the full DJMixStation 2 feat Virtual DJ from eJay and upgrade, I can't find how to use a headphone or an external mixer.
Posted Thu 22 Jan 04 @ 1:53 am
Redskin, it's because you can't.
DJ Mixstation 2 are a limited version of Virtual DJ, you can see the difference here : https://virtualdj.com/products/comparison.html
Regards
Coyote
Regards
Coyote
Posted Thu 22 Jan 04 @ 2:24 am
I have the same problem of sound when I activate the limiter in the FAME parameters (options menu)
Posted Sat 24 Jan 04 @ 2:17 pm
Posted Mon 20 Mar 06 @ 3:27 pm
i have had this same issue in the past. Here is what i did,
1. It could be a heat problem with your labtop. Are you using a chill pad?
2. Watch you gain, It does gradually change if you have the auto gain on.
I also purchased a a Sonic Maxiumizer. They start at about $149 but they are extremely worth it! even for djs whom still use records or cds.
Posted Mon 20 Mar 06 @ 8:02 pm
