Forum: Old versions
Topic: Sound Problem
Laptop configuration:
Pentium VI 1.7 Ghz
256 RAM
Soundcard: Crystal (WDM)
OS: Windows XP Home
The problem is that the sound is not clear...
I hear it as much compressed...
Can someone help me????
Thanks very much!!!
Francesco
Posted Mon 22 Jul 02 @ 11:37 am
See the FAQ please (at skipping problem)
Try to reduce the acceleration in DirectX configuration (DxDiag in Execute command)
What is your output?
Are you hearing the sound out of an amplified system, or from your lap top?
Does it sound the same on both outputs?
Does it sound the same even when you use headphones?
Does your driver have an in-built pre-amp mixer?
What is your MP3 bit-rate?
What are you Atomix equaliser settings?
CAN SOMEONE HELP
I HAVE A CREATIVE SOUNDBLASTER AUDIGY 3D 5.1 SOUND CARD
THE PROBLEM IS... AS SOON AS YOU PRESS THE SELECT BUTTON.... THE TUNE IN THAT PLAYER STARTS TO PLAY... AND WILL NOT STOP UNTIL YOU UNPRESS THE SELECT BUTTON FOR THAT PLAYER......IT WONT EVEN STOP WHEN YOU PRESS THE STOP BUTTON OR THE CUE
AND AGAIN......NO MATTER WHAT I DO... IT WONT CORRECT IT
PLEASE HELP
THANK U
PS MY SOUND CARD IS A 24BIT
Now, this is what I am missing, who's having te problem, and who needs the help?
IM HAVING THE PROBLEM...... TOUCHOFCLSSSOUND..ADDY....
PLEASE HELP
AS SOON AS I LOAD A TUNE.. IT STARTS TO PLAY BY ITS SELF
ALSO
I NOTICE THAT WHEN I HAVE ON THE AUTO BEAT MATCH..... IT CAUSE THE TUNE TO GO FAST AND SLOW.. SOME TIMES SOUND LIKE ITS GOING BACKWARD
'PLEASE LET ME KNOW WHATS THE BEST 3D SOUND CARD TO USE... ASAP.. SO I COULD TAKE THIS ONE BACK.. IF ITS NO GOOD FOR THIS MIXER....ITS ONE OF THE TOP OF THE LINE SOUND CARD.....BY CREATIVE..SOUND BL;ASTER
THANK YOU
