Forum: Old versions
Topic: Microphone input possible???
Is it possible to use a microphone to talk during broadcast mixes???
if yes? How?
Posted Sat 15 Jun 02 @ 12:54 pm
yes i think so! you can put a pc microphone into your "mic" input on your soundcard and in the brodcasting plugin there is a microphone option and there is a button "push to talk" press that to speak or you can do it through your mixer!
thanks I'm gonna try it out!
Doesn't work... when I press the "TALK" button, people don't hear me, or not loud enough to hear what I'm saying... i checked my volume settings, and I noticed that when I press the "TALK" button, in my mixer panel the "MONO IN" setting automatically will be put to minimum level
do you know what's wrong? I tried every setting I could
i think in the "input" tab on the plugin you need to click "open mixer" and make sure you have "microphone" checked ok if it doesnt work get back to me!
I saw an lengthy and very informative post about this on the technical supportforum over at shoutcast.com, pasting it in here would be a mess but just have a look over there and you'll probably find it
