Forum: Old versions
Topic: CDROM Problems
My systems is as follows
AMD K2 500Mhz CPU
256mb RAM
voodoo two
SB Live
Adaptec AIC-7850 PCI SCSI Controller
and Matsushita (panasonic) CW-7502 and CR-508...
My CW-7502 is a burner and happily plays digital music through atomix, however the cr-508 which is newer fails to do this, and it isnt the cd that is the problem... plz help.....
thanx,
.::DJ Ben Jammin::.
Posted Mon 15 Apr 02 @ 7:57 am
What do you mean by "digital music"? mp3, wav or cda?
CDA
it wont play bloody audio CD's!!!!
thx...
.::DJ Ben Jammin::.
I am runnin ME
thanx man, ur a great help...
im downloadin the drivers now...
.::DJ Ben Jammin::.
ohk bad news.. i downloaded the ASPI drivers and it tells me that mine are all working properly............
what could then be the problem... i cant hear my CD's :'(
i dont want IDE CD ROMS noooooooooooooooooooo
.::DJ Ben Jammin::.
But, can you hear your audio-cd's in winamp or windows media player? I mean, is it a problem of atomixmp3 or a problem of your entire windows?
its a windows prob
nothin can play audio cds digitally
.::DJ Ben Jammin::.
Have you gone to control pannel, sound devices and checked that you don't have the digital cd volume low or muted in your soundcard/s?
Have you got your cr-508 conected to your SBLive?
This seems the help of windows... Cross the correct:
_ Yes
_ No and we'll pass to the next question. ;-)
Ok, look at the real windows help and perhaps we'll finish earlier with this.
for digital music it shouldnt require to be connected to the sb live should it?
i dont have WDM drivers for my sb, im runnin win ME...i could use WDM drivers and im sure it will run smoother
that was my message before soz...
I forgot to login lol...
.::DJ Ben Jammin::.
