Forum: Old versions
Topic: USB sound card
did atomix support USB external sound cards?
and which one?
Posted Tue 09 Apr 02 @ 8:49 pm
Yes all of them but in full 2,1 version.
SB Extigy is well supported.
yeah all of them are supported by ATOMIX
Ok, the Sb Extigy is supported,
But when I select the 3D option in sound configuration and use the front output for the speakers and the rear output for the headphones, the system crashes after a while.
The system works fine if I use the dual soundcard option.
(speakers connected to the front output of the SB Extigy and the headphones connected to the internal soundcard.
Do I do something wrong here?
DJ Appie
Doesnt crash on mine..... sorry I can't help but it's exam week!!!
SAme HERE !!!!!!!!!! I HAVE 3 EXAMS TOMMOROW AND LOOK WHAT I AM DOING HERE !!!!!
yeah, im actually IN a business class presentation right now... talk about time management lol
yes it does. I use a M-Audio quattro. but it doesn't detect the second pair of outputs ...
Somebody mentioned that the sound quality was better when using two-soundcard-option than using 3D-soundcards in 3D-mode. Have you guys experienced this?
Is Extigy a good solution if you want to use it with an external mixer? Are the back and front signals evenly leveled in terms of volume (any difference in sound quality)?
- Jim
