Each time i open atomix there is no shortcuts loaded. I have to load the shortcuts before i begin playing music in atomix.
Any suggestion????
Any suggestion????
Posted Tue 26 Mar 02 @ 9:47 am
Did you shut down the program after mixing? If it crashes, your settings were not saved.
On my XP system, it works. Try to save your shortcuts layout with another file name.
Posted Tue 26 Mar 02 @ 9:58 pm
I also have no problems with XP, I set mt shortcuts and then save.
DJ Homeboy
DJ Homeboy
Posted Wed 27 Mar 02 @ 4:55 am
the program closes properly. also i save my shortcut with different filename many times and still nothing. When the program close my preferences stay there except the shortcuts.
Posted Wed 27 Mar 02 @ 6:38 pm
