Forum: Old versions
Topic: Sound Blaster Audigy MP3+
Hey guys! I am interested in buying this product so I can have 2 outputs. Right now I have a Forte Media FM801, with a front and rear outputs, so I tried usind the 3D card option in Automix but for some reason it doesnt work. I also tried putting in two sound cards(and works just fine), just the sound quailites arent the same. So I wanted to ask if anybody is using the Audigy and does if works properly under the 3D option??
please help.
Thanx!
Posted Mon 11 Mar 02 @ 3:56 pm
Two soundcards or 3d soundcard configuration works only in full version of atomix. I think 99% it will work with audigy.
I am using the Sound Blaster EXTIGY right now on my laptop for a second sound out and it works extremely well. The only problem with it is that there is a slight lag time...
yes the sound blaster audigy platinum
is exelent for atomix
I just installed one last week
i highly recomend it
i used to have monster mx400 sound card
and had the same problem
My setup-ASUS-A7V133 mother board
AMD-ATHLON 1.4 G
256 mb sdram
WIN 98SE DirectX 8.1
External
Newmark DM 1100x mixer
2X Technics SL-1200MK2
I have front & rear channels to line1 & 2 (mixer)
& the 1200s to phono 1 & 2,
booth/zone L/R to line in (sound card) to record
