I downloaded Mp3 Workshop and it looks great for freeware so i did the following things, with my already existing mp3's
I normalized my mp3's and i set them to 128 k/bits instead off 198 k/bits afther i did this atomix wont accept my mp3 files and winamp did.
then i did it all again but then i set the bitrate to 98 kits and now all my files play too fast in winamp and atomix is still not accepting them!.
Posted Sun 10 Mar 02 @ 9:58 am
Oops! Did you change the KHz to anything else than 44,1?
Posted Mon 11 Mar 02 @ 6:10 pm
yes the program did it.
is there somthing to do or can i trow away the files??
Posted Tue 12 Mar 02 @ 4:22 pm
You might be able to re-sample them back to 44,1. Try a couple and give them the ear test before you delete them. Unless the original sourse is available to you, then you might be better off re-ripping them.
Posted Tue 12 Mar 02 @ 4:37 pm
