Befor I try this, has anyone had any conflicts with using 2 sound cards. I've heard that it can mess up your system sometimes.
What 2 soundcards are stable together? What 2 cards are other people using. I currently have a SB live 5.1 and thought about putting another one of those in but then thouht to myslef "This can't possibly work properly, they will probably conflict with each other".
So what other card should i whack in there?
Cheers, Kev
Cheers, Kev
Posted Wed 06 Mar 02 @ 7:30 am
If you already have an SB Live 5.1, why do you need another sound card? The SB Live already has two stereo outputs, which is all you need for the live playback and headphone monitoring. If you really want to put another card in, you /could/ put another SB Live in (or SB PCI etc) without any problems.
Cheers...
Swift
Cheers...
Swift
Posted Thu 07 Mar 02 @ 12:43 am
