Forum: Old versions
Topic: Crash Problem
I purchased Atomix and whenever I try to activate it it crashes. Whats the problem?
Posted Mon 04 Feb 02 @ 7:42 pm
Control if atomix goes in conflict with other programs. First: start atomix alone: close all running progs by using ctrl alt del. Second: you can use drwatson.exe (anticonflict program) to erase your conflict problems: drwatson is probably in c:windows; otherwise try to find it on your OS cd. Sorry for my grammar: i'm foreign :) Good luck
Peroz
