why when i use 2 soundcards i cant hear the sound effects
(the wav/mp3 files not the other effects...)
and why it works fine with one soundcard?
Guy
Guy
Posted Mon 07 Jan 02 @ 10:40 pm
Posted Mon 07 Jan 02 @ 11:06 pm
ok, i'll add some more details because i couldnt find an answer to my problem in your link...
i use p3 850, sb128 & sb64, 512mb memory & external mixer.
when i check the settings to one soundcard only i can hear the samples, when i change to 2 soundcards, none of them
playes the sample...
is there a way to change it to play the sample through both soundcards?
Guy
Guy
Posted Thu 10 Jan 02 @ 8:59 am
As posted in the other message:
The samples and the EQ´s can´t be used in hardmode. If you´re using the two soundcards mode, you´re in hardmode. We´re working on this.
Posted Thu 10 Jan 02 @ 11:05 am
