Forum: Old versions
Topic: Sound Effects
Would you guys know where to get good sound effects for use with the version 2?
I am looking for sound effects such as "space sound effects", "warps"..etc. and something that goes.."trrrrttt" (sort of like a "machine gun sound effect"). Sorry, I dont know the real technical terms for them :-). I just heard them from some of the mix cd's that I have.
Thanks for you help!
Posted Fri 21 Dec 01 @ 6:48 am
Try www.findsounds.com
It will search by format, quality, size.
