my problem is when playing ether desk and cueing
the other I can faintly hear the other track as an echo
in both headphones and speakers
My setup-ASUS-A7V133 mother board
AMD-ATHLON 1.4 G
256 mb sdram
diamond sound MX400 3d sound card
WIN 98SE DirectX 8.1
I have rear channel to pc speakers
and front channel to headphones,
in sound config I have selected 3D card
speaker/headphone config
( yes I have 4 speakers selected for card
propertes, in multimedia and have selected
quadraphonic speakers)
any help
AMD-ATHLON 1.4 G
256 mb sdram
any help
Posted Mon 19 Nov 01 @ 10:41 am
i recomenden you to buy a second sound card ( a sb cheap ca by right)
if you donĀ“t want to buy, try to select in the mixer of your sound card only line and aux o anything like this, Record must be off, mic must be off, etc..select differents combinations to find the correct but if everything is the same, buy a cheap Sb
Get Lucky!
Get Lucky!
Posted Wed 21 Nov 01 @ 2:56 am
Thanks I'm running v2 now the problem was still there,
so I changed the volume setting I never really looked into these settings before half of the faders wern't
visable and wasn't muted, I have corected these settings
and it seems to be working OK, thanks again.
seems to be A good tip for anyone with A 3D sound card
re: V2 so far I'm very impressed with the additions
Posted Fri 30 Nov 01 @ 3:27 pm
