I've got the full version of atomix + a 3d sound card (creative 1024). + Windows 2000
1) i can't monitor a tune even though i've got a 3d card
the same tune plays from both sets of speakers
is this a bug with windows 2000?
i've configured my sound card for 4 speakers
Help - i bought this sound card especially for this
+ this product rocks
Posted Tue 26 Jun 01 @ 2:41 pm
I tested this configuration, and it works great, so it's not a bug of Windows 2000.
You should follow these steps:
- In "Sound card configuration", check if you configured Atomix correctly: One 3D sound card, Speaker + Headphone
- If the problem is not resolved, re-check your sound card configuration (4 speakers and not 3D envorinnement for example)
- If needed, reinstall the last drivers from Creative, and the last version of DirectX
- If you had the evaluation version before the full one, check you have completely removed the previous version. You should unistall Atomix, erase the Atomix folder in Program Files directory, and reinstall the software.
Hope that helps ! Please post here your results.
Dams
Dams
Posted Tue 26 Jun 01 @ 4:22 pm
