Forum: Old versions
Topic: Swapping monitor/output
DaSOHome userMember since 2001
I am confused. For some reason, Atomix outputs the mix to the rear channel and the monitor to the front channel of my soundcard. I cannot find a way to swap this within the sound card software. The problem with this arises when using an external recording program. It ends up recording the monitor and not the mix because it records the front channel. I can not select the channel to record, it only allows "what you hear" or the front channel. I am using Creative Recorder that came with my sound card - SB PCI512. Anyone know of a solution?
Posted Mon 11 Jun 01 @ 9:11 am
Record your mix with Atomix's own recording function.
Posted Mon 18 Jun 01 @ 11:19 pm
