I would like to know what the option of "crossfader"(crossfader behavior when hovered over) means
there are three optoins(smooth, full and cut), could some one tell me what each one means
THANX
DJ BLANK SHOT
THANX
DJ BLANK SHOT
Posted Sun 06 May 01 @ 4:11 am
Smooth = Volume of each decks are about 3/4 full volume at the half-way point of the crossfader.
Full = Volume of each deck are at thier maximum at half-way point of crossfader. Just like a real hardware mixer.
Cut = When crossfader crosses the half-way mark, only the track on the side that the fader is on will be heard.
Hope that helps.
Hope that helps.
Posted Sun 06 May 01 @ 9:36 am
Hi !
See also my answer to the previous message (on the exact same topic :).
Posted Mon 07 May 01 @ 2:02 pm
