Hi, It seems that if you use a Serial 2 USB cable to connect the DMC-1 to your laptop that it doesnt work wirh Virtual DJ.
Posted Sat 20 Dec 03 @ 9:07 pm
It depand which adaptater you use.
I got one and it work perfectly, i buy it on a standart hardware shop, so i try it before buying.
Posted Sat 20 Dec 03 @ 9:12 pm
Which brand do you use?
Posted Mon 22 Dec 03 @ 12:05 am
There is a No Name product.
Posted Mon 22 Dec 03 @ 12:11 am
I think I read in some other forum about 6 months ago that somebody had success with an adapter they got from Radio Shack. This was with PCDJ though I think... but it might be the same problem your having now with VDJ.
Posted Mon 22 Dec 03 @ 5:09 am
I have used a serial to usb adapter to plug a DMC-1 and it work with VDJ. There isn't problem.
Mine cost 29€ (in France with taxes)
Gwenn
Gwenn
Posted Mon 22 Dec 03 @ 3:34 pm
