Hi,
there is a small bug in the skin.
The pitch from channel 2 is same as channel 1.
Here is how to fix:
Open the NumarkCDN-88.xml-file with notepad or another texteditor and scroll down to section channel 2.
search for these lines
textzone chan="1"
size width="61" height="14"
pos x="946" y="152"
text font="tahoma" size="14" weight="bold" color="#626956" align="center" format=" pitch
textzone
change chan="1" to chan="2"
that's all.
greetz
Janosch
Here is how to fix:
textzone chan="1"
pos x="946" y="152"
textzone
that's all.
greetz
Janosch
Posted Sun 31 Mar 02 @ 5:00 pm
Janosch could you fix it and submit you skin again ? So it'll be fixed on the skins page.
Thanks.
Thanks.
Posted Sun 31 Mar 02 @ 5:10 pm
ok null problem. I will send you the Numark skin again tonight.
Should i also send you the other skins because i've updated all of them (cue button, comment line and error fixes)?
Posted Sun 31 Mar 02 @ 5:38 pm
yes! :-)
Posted Sun 31 Mar 02 @ 6:44 pm
To all who have downloaded the skin please download it in the add-ons section again and replace it with the first one. I have fixed the errors in the update.
Thanks to the team you're really fast!
greetz
Janosch
greetz
Janosch
Posted Mon 01 Apr 02 @ 12:43 pm
LOL thx to you Janosch :))
Posted Mon 01 Apr 02 @ 2:17 pm
