heya , guys ..
this is my problem ...i recently upgraded to a 40x CD writer
which is my main cd rom , in my pc . while i am mixing ,
i put a cd in the cd/rom & close it ...
then it skips for about 3 secons , seeing that my mp3 collection is on cd , is there any way that i can
my pc not to do this
Ps , its a brand new CD-writer (so i dont think ist the writer )
also i have set set win98 to no read ahead as well ...
any other ideas wil be greatly aprciated !!
many thanks
-if its 2 loud ur 2 OLD.....-
many thanks
Posted Wed 25 Sep 02 @ 10:16 am
          Is there any chance that the CD your trying to play is Depeche Mode's "Master and Servant"? :)
...because it sounds to me like it's a classic case of Master/Slave configuration.
Do you have your harddrive and CD-drive on the same IDE-channel/cable? That might lead to problems like this one where the CD takes control of the IDE-channel forcing the HDD (acting as a slave without a doubt) wait for it's turn and thereby causing a delay in the diskreading.
The solution is simple: have your harddrive and your CD-drive connected to different IDE-controllers so that you have one IDE-cable to you HDD and another to you CD or make sure that the HDD acts as a server which means that the CD would have to wait for its' turn instead which probably won't be a problem with a 40x CD-reader
Posted Wed 25 Sep 02 @ 12:14 pm
